Hi everyone. I’m new to this forum. Hope you can help me through building my first multirotor system for professional aerial filming. I decided to build an octocopter for heavy-lift related filming with cameras such as mark3 and the red epic (yes I do have access to one
I did some research and decided to go with the following parts and I have a few questions to ask you guys ; maybe you could give me some advice to complete my part list.
1x Tarot Iron Man 1000mm Octo frame (from foxtechfpv)
8x Sunnysky 4014-12 320kv motor (from foxtechfpv)
8x (an alternative to sunnysky) T-motor 3515-15 400kv motor(from foxtechfpv)
8x Hobbywing platinum 40A ESC (from foxtechfpv)
4x CF 1447 prop. (from foxtechfpv)
2x Foxtech 6S 9000mah Lipo Battery (from foxtechfpv)
Now here comes all my questions J.
· I’m planning to go with a cinestar gimbal (preffering a 3 axis CS gimbal). In most forums I see it’s possible to mount a CS gimbal to Tarot Iran Man frames. Does anyone know what extra pieces I would need to obtain to mount it ? (screws, brackets etc, or the type of DIY I’ll be dealing with). You could give me suggestions for other gimbal makes too but consider I’ll be flying Canon 5D mk3 or the red epic.
· I’m not too familiar with multirotor electronics and probably I’ll be having some friend helping me to put all these parts together (I mean the electronics etc). I’m planning to go with DJI wookong M controller. What would you suggest? I need something easy to use and set or calibrate.
· I haven’t decided what to get for the remote controller. Rx Tx so I’m open to any suggestions. I’ll probably be needing 2 controllers (multirotor + the gimbal )
· Talking about the gimbal, what type of electronics would I need to get for the gimbal ? Like the stabilization, servos etc. I have no idea.
Hope you can help me complete my list of parts and knowledge. I know you are probably saying don’t try n build a system like this if you don’t know how to. But hey ! we all need to start from somewhere. I have an ideal budget to build it so I’d rather buy build and try to do it. I would also be very happy with any info or tutorial/material you could provide me with about putting all of these together, like the Li-po’s the flight control electronics the Rx Tx etc. This is going to be a nice and adventurous process for me. Thanks in advance for all your help J
