Lanzar
Power Distribution Board for most advanced users.
For OCTO Multicopter (Equipped with 16 pair of 3.5mm plug)
SPECIFICATIONS
- Up to 8 ESC/Motor can be connect to the Board
- 260A (Continuous), 320A (Peak)
- 2 layout with 2oz(70um) Copper Dual PCB.
- Gold plated with black soldermask
- Φ64mm body mounting
- 1 PCB plate for(+), 1 PCB plate for(-)
- Weight : 85g
- Size : 105mm x 105mm
Power Disc BEC (GSR-5030DM)
5V,12V Dual BEC for Multicopter
The Gryphon Power Disc Dual BEC.
Dual voltage BEC regulator designed for Multirotors systems.
It accepts voltages inputs from 14.4V up to 30V(4~7 LiPo Cells), and has 2 independant BEC outputs.
User selectable 5.6~8.4V, 5A on BEC1 output (For Camera, Retractable landing gears, Gimbal servos,flight controllers...)
And 12V, 3.5A on BEC 2 output (Camera, Video Transmitter, LEDs..)
CONTENTS
1. Main PCB : 1 EA
2. Power Output Molex Connector Cable(L=30cm) : 11 EA
3. PCB Post Female-Female 3 x 5mm : 4 EA
4. PCB Post Female-Female 3 x 10mm : 4 EA
5. Socket button head screw M3 x 5mm : 8 EA
6. Socket button head screw M3 x 12mm : 4 EA
7. Power Input Molex Connector Cable Ass’y : 1 EA
SPECIFICATIONS
Input voltage : 14.4V~30V(3~7 LiPo Cells)
Output voltage : BEC1 : 5.6V, 6.0V, 7.4V, 8.4V Selectable
BEC2 : 12.0V
Output current : BEC1 : 5A(Continuous) @ 22.2V
BEC2 : 3.5A(Continuous) @ 22.2V
Size : (Φ)100mm x (H)11mm
Weight : 28g (Exc. Cables)
SPECIFICATIONS
- Weight : 85g
CONTENTS
1. Main PCB : 1 EA
SPECIFICATIONS
BEC2 : 12.0V
