Closed: ZLRC SG906 Beast Camera not tilting
Bobgs906
Hi all,
I have a ZLRC SG906 drone "Beast" which has a rotating camera.
I tried with the 2 buttons on rhe right side (back) of the remote and with the holder slider in the APP but the camera won't tilt.
I have removed the camera and checked movement, it is free.
I bought it from someone and he told me it worked fine at his side.
Can I be something wrong or check out something about this?
Bobgs906
Found it, it only works when actually flying, not when it is turned on and standing on the ground :)
Case closed.
Jamie Schrader
Case closed.
Does your camera move all the way up for FPV mode/ picture? Mine will not go all the way up so flying is not possible unless you are staring at it. Or if you are way above the trees.
