X Specifications
X8 Specifications
Additional Specifications
- Motors: 4-T-Motor U8II
- Propeller size: 29”
- Weight: ~14.5 lbs. / ~6.5 kg
- Max payload: ~8.7 lbs. / ~3.9 kg1
- MTOW: 37 lbs. / 17kg
- Power: 16Ah to 44Ah @ 44v1
- Flight time: ~10 – 45 minutes1
- Control range: ~5 miles / ~8 km
- Max speed: 65 mph / 100 km/h
- Dust & water-resistant
- Power plant(s) 1,000 hour TBO
- Maximum thrust ~64 lbs. / ~29 kg
X8 Specifications
- Motors: 8-T-Motor U8II
- Weight: ~19 lbs. / ~8.6 kg1
- Max Payload: ~15 lbs. ~6.8 kg1
- MTOW 2: 25+ lbs. / 11 kg
- Flight time: ~10 – 35 minutes1
- Control range: ~ 5 miles / ~8 km
- Maximum thrust ~128 lbs. / ~58 kg
- Diagonal Wheelbase: 1,200mm
- Autopilot: Pixhawk 2.1 / CUBE, Orange (Made in Taiwan)
- FPV Video: High Definition FPV Video
- Ingress Protection: Water & Dust Protected (IP Testing In Progress)
- Ground Station Controller: your choice of radio
- External Power: 5v, 12v, 24v, 50v
- External Communications: SBus / Serial
- External Video: Supported through external HDMI Connector
