Zenmuse Z15 GH4 Non responding
Hi, I'm adjusting a GH4 Zen, the problem I'm having with the configuration is that the Gimbal Assistant does show my Transmitter imputs but the ZEN does not respond, it's like in free mode.
Gimbal assistant does not have a lot to configurate so I do not know what else can I do.
Many thanks in advance
Benjamin Kenobi
Easy? You call that easy?
Okay, what transmitter are you using?
Is the zenmuse fully plugged in?
Does the mode switch on the assistant work?
I'm using Futaba 10J for the operator, no S-BUS connection
The Zen is fully pluged.
Modes work in the assistant but not in the ZEN.
Benjamin Kenobi
So the Zenmuse doesn't respond to transmitter commands at all? It just wanders around on it's own? Are you using an A2?
