When you configure a machine to be Y6, what size difference do you use on the prop on top vs the props on the bottom. Do you go up or down on prop size or do you use use a different pitch? My prop are CW on top and CCW on the bottom. I have a yaw issue, and I am sure it is because the props on the bottom are not grabbing enough air.
