Wookong M not connecting to software.
es124
Wookong M wont connect to my mac, i have just two descending beeps and no connection to the software. The light on the PMU is on ( green ) but no light on the MC and only when connecting the battery tree lights from the led and then nothing. the receiver is connected and the transm. light is on.
Is there something wrong with the MC ? And how can i test this ?
I was installing the previous firmware version ( yaw problem with the last version = http://www.multirotorforums.com/showthread.php?3829-DJI-WKM-yaw-issues ) and then on finish install the usual beeps started, i disconnected the batt. and restarted and now i only have two beeps. ( and no led blinking )
Enno
Belgium
VINHEX
Does the main control unit have a red light, if not maybe a firmware upload fail. May need to reset.
VINHEX
If there is no light it sounds like firmware failed I had no light on unit and Contacted DJI and was advised to.
Quote from email: Pls connect M5 and M6 together then connect to assistant software to reupgrade.
Did the above and all started to work again..
Vin
