WKM controller #2 arrived today and this evening it replaced the MK stack on a small quad that now has tall landing gear and a two axis GoPro only mount under it. The quad frame is/was my testbed for trying out different flight control boards, the Mk stack that was on it was connected through an I2C converter and it flew fairly well, I had planned on making it into a dedicated FPV multi, now it's a low end APV machine with WKM controller. Setting up the second WKM goes a lot quicker and easier than the first plus I left just about everything at default settings and copied the model setup in the TX from the WKM Hex so there wasn't a lot of setting changes needed. First flight happened about 45 minutes ago in the dark backyard with only the light from the LED strips under the arms to see by. From what I could see of it, it appears to fly perfectly on the default settings, quite unlike it's big brother hex that weights significantly more and wouldn't fly worth a D**m on the default setup.
I'll have to wait until daylight to see how it really flys but I don't expect it to be much different than it has flown with any of the other controllers that have been on this frame, I actually expect it will fly better than it did with the others. If it's not raining in the AM I'll put one of the GoPro on the mount and give it a good test flight to see how it compares to the now well tuned WKM Hex.
