Wiring naza to Spectrum AR 8000
38super
Hi all....Still new to this and loving every min. Question. How do you wire your naza-m to a receiver like the spectrum ar8000? The naza Mc has a notch I think on the ground side that fits the MC . The Spectrum ar8000 has totally different plug . What kind of harness do I need to fit naza to AR8000. Also would like to know is it advisable to put a dap of hot glue on solder points? Iv'e seen this done on more then one video First build so forgive me ...Will
Stock F450/ GPS/ GoPro/ DX7...............PS anyone thinking of naza H for a heli that has not been used in a long time because I JUST COULD NOT FLY THOSE THINGS, I have Two and would like to get them in the air Thanks
The odd looking plugs are the satellite (not to be confused with space junk) receivers and accessories.
The receiver wires up the same as any other Rc receiver and the signal wire goes toward the outside edge.
It's fairly well defined in the manual. If you don't have a Naza manual,,, good luck. Or you can download it at the DJI website.
FlyGirl
As far as the connectors go, you have to carefully cut off that little flange that is on the NAZA connectors so it will fit into the ar8000 slot. It's not hard, just do it carefully. The hot glue is used just to insulate the open solder points so something can't inadvertantly ground out to the solder points. Not a bad idea.... Good luck to you!
