Just what to see what Tx and Rx combo people are using with their new Naza GPS units? Right now I have a DX6i but no GPS. Will i need to upgrade Tx if I want to use the GPS for the Naza?
Any insight appreciated.
DX8 and you don't have to upgrade if you read close you can use the two switch combo and just have gps atti and atti with no manual selection. My Rx is a AR8000 because it supports failsafe!
You will still need to be able to toggle between manual and GPS mode to do the compass calibration. You can set the endpoints on the switch channel to do that and then change them to just ATTI and GPS but it's a lot easier if you have a 3 position switch or two available especially if you want to use IOC and Home lock functions.
Thanks for all the responses! What a wealth of knowledge. You all rock!
So just to clarify, I will need a Tx with 2 three position switches on it to utilize all the capabilities of the Naza GPS?
Thanks again for the insight...
Hi all,
First post here
I'm looking to buy a DJI F450 and use a DX8 with AR8000. I've seen various boxed packages for the DX8 for sale here in the UK. Some come with a telemetry module in the box, is this required?
This is the website for one of my local shops listing the various DX8 packages, not sure which one I need:
http://www.inwoodmodels.com/advanced_search_result.php?keywords=dx8&x=0&y=0
only if you want to see like battery voltage and a few other parameters really, which require sensors as well - you are fine to go with the regular DX8 for £179 at Inwoods ... also my supplier of choice for the DX8 when I got it ...
