Waterman123
Hey guys,
I'm looking to hear your charger recommendations. And most importantly any chargers that charge 4 batteries at once? I have many different batteries, so not sure if you can parallel + balance charge multiple packs at once, or if I need 4 chargers?
For $122 I created my own 4 pack charging station with HobbyKing parts. ($42 power-supply, 4X $20 6S Balance chargers). I started with 1 charger and it worked great for weeks. 5000mah battery in 1 hr at 4amps, or 2 hrs to balance.
Of course, within a day of receiving the other chargers, 3 have failed and I get a "connection break" error and 1 started smoking. One has been rock solid, the other 3 broken within a day.
1. The good thing about this type of setup is that 1 charger fails, you still have multiple back-up and just need to replace/return broken ones.
2. It came with all the wires and balance plugs, instead of buying each wire separately.
3. It was $122 for 4 battery chargers
4. They are small chargers for traveling
BAD THING: 3 out of 4 of these cheap chargers broke with-in a day.
SO, I need 3 replacement chargers or 1 (4 port) charger that isn't too much $. Any recommendations?
