What Micro Quad Will You Use 300mah 3S On?
Flora
Tattu 11.1V 45C 300mAh 3S Lipo Battery Pack with XT30 plug provide high quality, reliable power for your micro quad or FPV, but what quad or fpv, you'll put it on? :confused::confused::confused: pls reply to me below. Just wait for you!;);););)
Brand Tattu
Capacity(mAh) 300
Voltage(V) 11.1
Discharge Rate (C) 45
Max Burst discharge Rate (C) 90
Configuration 3S1P
Net Weight(±20g) 32
Length(±5mm) 52
Width(±2mm) 19.5
Height(±2mm) 19
Connector Type XT30
Wire Gauge 18#
Discharge Wire Length(mm) 65
Balancer Connector Type JST-XHR-4P
Balancer Wire Length(mm) 45
Trevcharl
Brand Tattu
Capacity(mAh) 300
Voltage(V) 11.1
Configuration 3S1P
Net Weight(±20g) 32
Length(±5mm) 52
Width(±2mm) 19.5
Height(±2mm) 19
Connector Type XT30
Wire Gauge 18#
Trevcharl
It must be a small little battery for a small copter? You mention Microcopter, one will need to know the current of all the motors, then you can make a calculation. The current drawn by FC and camera, take it 100ma (It could be more or a lot less) The total current average Ta, and the battery Amp/hour Ba So the time you have to fly will be:-
Time in hours = Ba/Ta. You will have a fraction here, so just multiply by 60, that will give the minutes. Now you can select the appropriate Microcopter you can use? Hope this helps?
