quadcopter expert
Walkera TALI H500 With Ground Station+DEVO F12E+G-3D+ILOOK+ RTF
ONLY!!!!! $1258.99
BUY HERE http://www.banggood.com/Walkera-TAL...LOOK-RTF-p-953297.html?p=PU17212820170201510D
Description
Brand Name:Walkera
Item Name: HD FPV Hexrcopter
Item NO.: TALI H500
Fight time: up to 25 minutes
Battery: 22.2V 5400mAH lithium-polymer battery
Version: H500 With ground station function
FPV Transmitter
Channel:12CH
Downlink: 5.8GHz
Monitor:5’’ LCD monitor
iLook+ Camera
Video Resolution HD 1920*1080P
Video Frame Rate 30FPS
Video Format MOV
Video Compressing Format H.264
Image Pixel 300
Resolution 4032*3024 Pixel
Video Format MJPG
Standby Power Loss 1.33W
Working Power Loss 1.9W
Supply Voltage 3.7V-5V
Working Temperature -10~+70℃
Lens Spec 1/3’’
Lens Angle 170°(MAX)
Weight 125g
Features
With ground station function(use the same ground station with Walkera Scout X4)
Waypoint mission planning
In line accordance with the fact of light requirements to set airline and flying over the horizon(OTH).
total 128 waypoints
Designated Flight
Touch mobile screen and set take-off point and destination,it will under control anytime.
Follow me mode
Pre-set the object to follow,no matter wherever it go,the plane will follow it and won't lost.
Follow record track back to home
According to the pre-set airline,click the back button,the plane will turn back along the route.
The perfect all-inclusive FPV solution
Perfect compatibility with GoPro Cameras
Flight time of up to 25 minutes
Package includes a professional 12 channel FPV radio,
3-axis gimbal and HD camera(iLook+)
5.8GHz downlink, 5’’ LCD monitor
Telemetry function allows users to monitor real-time voltage,
Temperature and GPS data
iLook+ HD Camera
13 Megapixel high-definition sensor
Designed specifically for aerial-photography with wide field-of -view
G-3D 3-axis brushless Gimbal
Easy to operate, active image-stabilization
Perfect compatibility with GoPro cameras
Fight time of up to 25 minutes
Large capacity 22.2V 5400mAH lithium-polymer battery
Intelligent flight battery- capable of showing remaining capacity and low voltage warning;Provides up to 25 minutes of flight time.
GPS Position Hold
Newest GPS flight control system, providing more accurate flight and position hold capabilities.
Hyper IOC(intelligent orientation control) function
IOC function could be activated regardless of aircraft heading
Auto-cruise function
The aircraft can automatically cruise around the perimeter of a customizable flight radius.
Return-to-home function
The aircraft autonomously return to and land at the take-off location when the return-to-home function is activated.
Return-to-home failsafe
If the aircraft strays beyond radio range, the aircraft will autonomously return to the take-off location.
Package Included
1 x TALI H500 Hexrcopter
1 x Devo F12E 12CH FPV Transmitter
1 x RX1202 Receiver
1 x iLook+ Camera
1 x G-3D 3 Axis Gimbal
1 x Charger
1 x Battery
ONLY!!!!! $1258.99
Description
Brand Name:Walkera
Item NO.: TALI H500
FPV Transmitter
Channel:12CH
Downlink: 5.8GHz
iLook+ Camera
Video Format MOV
Image Pixel 300
Video Format MJPG
Lens Spec 1/3’’
Weight 125g
Features
total 128 waypoints
Designated Flight
Follow me mode
iLook+ HD Camera
GPS Position Hold
Package Included
1 x RX1202 Receiver
1 x iLook+ Camera
1 x Charger
1 x Battery
