paulreilly
(Sorry I can't find a more appropriate forum for this question)
I'm using a TM1000 for telemetry on a WKM-based hexcopter, with a Spektrum DX8 on the ground. Power is a pair of 5AH, 4S lipos.
The voltage reading that shows on the DX8 is low by about 0.4V (compared with the battery voltage monitors, or a digital voltmeter straight across the battery). It's low whether the helicopter is flying or idle, so it's not a 'on-load' issue.
I can't find any way to adjust the reading, either at the TM1000 end or the Spektrum end. The only adjustment I can make is to the DX8 alarm threshold.
Can I fix this? Yes, I know I could adjust the alarm and live with it, but it makes the live telemetry pretty useless, and I've already got quite enough confusion, trying to remember that 'Voltage monitor 2 reads 0.2V high', etc.
For what it's worth, if I connect DJI Assistant on the PC to the aircraft, its Voltage screen gets the voltage reading spot on.
