ManticoreH
For sale: Full FreeFly Cinestar 8 package with a robust set of spares & tools!
This copter has flown flawlessly all over the USA, for several TV shows. Upgraded to take 5S flight packs, comes w/ 9 of them (current set has only been used on one shoot day). 3-Axis Cinestar gimbal with 3 FreeFly Radians. Comes w/ nearly enough spare parts to build a 2nd Cinestar (including a spare FC & BL), so it's ready for virtually anything! Also comes w/ a huge road case that allows it to ship fully-assembled (no time to re-assemble on a professional show, you need to be ready). All motor bearings recently replaced. Many upgrades, read on.
The full list is extensive, please read it all and browse pictures if interested...
Cinestar 8 Core Package:
Spare Parts:
Included Accessories & Tools:
The Road case and backpack have wear and tear, but everything else is in great shape! This package has only seen about 40 shoot days, with very few full-throttle maneuvers (most clients like slow & steady moves). Gets mind-blowing shots with serious cameras! Copter is in Los Angeles, CA.
We've spent at least $25K on this package with the upgrades & spares... We'd like to get $11,000 for it, send a serious offer. Message me if interested!
- FreeFly Cinestar 8
- MikroKopter flight control 2.1 (upgraded for 5S LiPos)
- MikroKopter BL
- (8) Quadrocopter QC3328 motors
- (8) APC 14x4.7 composite propellers
- FreeFly 3-axis gimbal
- (3) FreeFly Radians
- Upgraded 8-point vibration plate
- Upgraded (stiffer) vibration dampener rings
- Dual adjustable tilt bar
- Upgraded metal shaft & tube clamps (in key areas)
- V2 landing gear with extensions
- Manfrotto quick release & plate
- 900 MHz FPV system w/ camera (pilot)
- 4” TFT LCD monitor (for pilot FPV)
- 1.2 GHz wireless video (gimbal)
- Flat patch 1.2 GHz FPV receiver antenna
- Spektrum DX8 transmitter w/ upgraded thumb sticks (pilot)
- Spektrum TM-1000 telemetry unit
- Spektrum DX6i transmitter w/ upgraded thumb sticks (gimbal)
- (9) Turnigy Nano-Tech 8000mah 5S LiPo batteries (flight pack)
- (2) Turnigy Nano-Tech 2200mah 3S LiPo batteries (gimbal)
- (2) Quadrocopter 1200mah 3S LiPo batteries (pilot FPV)
- Hyperion EOS 0720i Duo 3
- PRC500 Power Supply
- Hyperion EOS 0606i
Spare Parts:
- Spare MikroKopter flight control 2.1
- Spare MikroKopter BL
- Spare Spektrum TM-1000 telemetry unit
- (2) Spare Quadrocopter QC3328 motors
- Freefly F360-0866 servo
- Freefly Potentiometer
- 8-Point vibration plate
- Original 4-point vibration plate
- Vibration dampener rings (full looser set for lighter cameras)
- (5) APC 14x4.7 SF composite propellers
- (5) APC 14x4.7 SFP composite propellers
- (3) 450mm booms
- 400mm boom
- (2) 100mm booms
- (2) 125mm booms
- 215mm boom
- V2 landing gear
- (12) Motor bearings
- GPS mounting assembly
- (2) Gimbal replacement belt
- Gimbal lightweight roll/tilt pulley
- Camera mounting plate
- (4) Boom end caps
- (2) Small servo pulley
- Tilt bracket
- Roll mount assembly
- (2) Dual bearing tilt mount
- Top boom connector
- Upgraded top boom connector
- Vibration dampening bracket
- (3) Boom connector
- (3) Servo mounts
- (15 pairs) Frame clamps
- (8 pairs) Metal frame clamps
- (2) Shaft clamps
- (2) Gimbal top frame plate
- Cinestar tripod screw
- Spare hardware (screws, nuts, bolts, etc. all sizes needed)
- Spare electronics (wires, cables, connectors, etc.)
- Color decal sheets: red, yellow, and blue
- Huge custom road case (45” x 45” x 22”) by Encore Cases
- Tamrac Expedition 8X backpack
- (2) Marmot hip bags for FPV receivers (stay mobile!)
- 40 watt soldering iron
- Solder station w/ magnifier & LED light
- Voltage meter
- IR thermometer
- (2) Lead solder
- Rosin flux pen
- De-soldering copper wick
- Heat gun
- Assorted heat shrink kit
- T-handle ratchet driver
- 2 & 2.5 mm hex drivers (multiple)
- Bearing installation tool
- Small handsaw
- Wire cutters
- Wire stripper
- Needle nose pliers
- Forceps
- Duffel bag
