David K Chavez
For sale is a complete RTF heavy lift aerial photography kit, including all components necessary to operate in a set environment. All gear was purchased in mid 2018 to mid 2019. Total investment was north of $52,000. The centerpieces are the Freefly Alta 8 and MoviPro Aerial Bundle. Gear was cared for meticulously and is in like new condition. Asking $35,000 for everything. Reasonable offers will be considered. Separating gear is not preferred but I'm open to the possibility.I will also offer basic training on the set up and operation of the gear if you are located within a reasonable distance from Southern California. Will ship anywhere at buyers expense. Items included are as follows:
Note: click red text for pictures
Drone:
Drone:
- Alta 8 + Case
- includes dual Futaba R7008RS receivers installed, installed FPV camera, pelican case, tools, and spare parts as included with a new purchase
- Freefly Backpack Kit (never used)
- Freefly Alta Extended Spacer (never used)
- Freefly Alta 8 Spare Parts Kit
- TBS Triumph Antenna Set upgraded FPV antennas on Alta and FPV monitor
- DS-30 Anti Collision Strobe
- FAA approved for night operations, flying under 107.29, includes custom wire harness with 9V battery case
- Futaba 14SGA transmitter
- Tarot Transmitter Cage (used lightly)
- Includes hardware to mount monitor and Teradek Rx, custom wire harness to power monitor and rx with lipo batt(not included), and body harness
- (16) Tattu 12,000mAh 15C Lipopolymer Batteries (8 sets)
- Maintained log of life cycles to monitor health, the most heavily used batteries still have a predicted 85% life remaining to function at full capacity (based on 200 cycle lifespan)
- Rotor Craft Custom Charger Case
- Mounted in Nanuk 930 weather resistant case: Revolectrix DPL6-T charger, Meanwell RSP2000-24(capable of 2000W on 220V outlet), step down converter, DPL wire kit, also included are 2 parallel charging boards-makes it possible to charge 12 batts simultaneously), EC5 charge leads, power cable (for standard 120v outlet), voltage checker
- (2) 1510 Pelican Storm Cases (in OD Green)
- Used to transport batteries
- Movi Pro Aerial Bundle + Case as described on Freefly’s website.
- MoviPro, MoviPro landing gear, Mimic with handle bars, Bush Pilot lens control knob, 2 MoviPro batts, 2 MoviPro battery chargers, MoviPro Aerial Bundle Pelican case, and other accessories
- Freefly Movi Controller
- Freefly Toad on a Stick
- Freefly Red Epic DTAP Power Cable
- Freefly XL Red RCP Serial Cable
- Freefly Twin 15mm Pop’N’Lock Quick Release
- Freefly Pop'N'Lock Screw Mount Quick Release
- (2) SinMax Wifi Signal Boosters
- Used to amplify Movi Controller Tx signal. Significantly improves range over stock configuration, includes custom DTAP power cable
- Teradek Bolt Pro 3000 Deluxe Kit SDI/HDMI Wireless Video Transceiver Set (Vlock)
- includes one Bolt Pro 3000 transmitter and two receivers, along with a black panel antenna array in an SKB water resistant Utility Case. Also included in the kit is a 14.4V single receiver V-Mount battery plate, all necessary cables, hardware, and power adapters
- 2 Rock Solid Master Clamps
- Rock Solid Low Boy Roller
- Rock Solid Aero Elbow
- Rock Solid Master Articulating Arm
- Rock Solid Camera Platform
- Used as monitor mount
- Rock Solid Baby Ballhead Adapter
- Rock Solid 22" Telescoping Arm
- Aero Utility Tray with Arm
- Fieldview 777SB DVR
- 5.8GHZ FPV 7" Monitor with built in battery
- FeelWorld FW759
- 7" Ultra HD 1280x800 IPS Screen Field Monitor
- (2) Ecoflow Rivers + Soft Cases
- RIVER Ultra-Capacity 500-Watt Portable Mobile Power Station for 2 AC and 6 USB Ports each
- Eartec UL4S UltraLITE 4-Person System
- Includes Single-Ear Master Headset and 3xSingle-Ear Remote Headsets, battery charger, and 8 batteries (1 extra set), also includes soft case
- (4) Motorola T600 Talkabout Radios
- Two Way Series 22-Channel FRS/GMRS Analog General Radio, includes 4 radios and 2 chargers
