UAVrc Multicopter ESC 4~12s Lipo HV 40A-OPTO
NEM
UAVrc New version HV40A-Opto ESC
attachment.php
only 33 grams,
The NEW ESC from UAVRC build in with aluminum PCB Board for the Power Module and Epoxy PCB Board for Central Processing Unit (CPU), both Modules attach together with connectors.
  • Build in Aluminum PCB Board for the N-FET Mosfet Power Module
  • Fit to any Boom 25mm and Above
  • Auto Recognition to any Brushless Motors
  • Auto Recognition for Input Voltage
  • Three Stage of start up Soft Start, Standard, Hard Start
  • Auto Governor Mode, also can be set as you wish (need the uavrc USB programmer, option)
  • 25MHz Internal Crystal Oscillator (provide the most stable Operation, that you can see)
  • You Can Set the Motor Timing (need the uavrc USB programmer, option)
  • You can Set the Drive Frequency 8KHz, 12KHz and 16KHz (need the uavrc USB programmer, option)
  • You can Connect External LED (need external Power) to check the ESC Status and have also Lights
attachment.php
HV40A-OPTO a
s a result of all these wonderful features, delivers excellent performance and handles Stable operation and extreme continuous current like no other ESC Up to 65A Burst Current.
More Info:
http://www.nem.gr/uavrc-esc-hv40-opto-for-4~12s-lipo-suitable-fo-all-bl-motors-p34319.html
http://www.uavrc.com/index.php/mult...tems-brushless-high-resolution-multi-esc.html
Kind Regards
Manolis Nikoloudakis
www.UAVrc.com
www.nemhobby.com
www.nem.gr
