turnigy plush 30A ESC get super HOT very fast....
MulticopterMaui
900mm Vulcan UAV Frame - one week old
6 Avroto 2814-11 - one week old
6 plush 30A - one week old
2x 4s 5000mah - Brand New
Gruapner 11x5
total weight 8lbs
Flys great......But......
after 4 minutes hover only.....
ALL 6 ESC are VERY VERY HOT...
Hover Specs
amps - 45
Watts - 600
each esc has 7.5amp to hover...
looks like 100 watts to each motor to hover...
Everything is COOL.....motors and batteries.....
ESC.....SUPER HOT....Almost cant touch them for a few seconds...
Can ANYONE PLEASE help......
what's the ESC timing set to? my personal preference with the Avroto motors is Medium. Ben's question about the batteries is perfectly reasonable also.
bart
Stacky
My Hexa weighs 4kg which is heavier than yours and with 11x4.7 APC props is hovering at 40 amps which is 5 amps lower than your yours. Im using 40amp plush esc's but your 30's should be fine. Mine are not even luke warm when hovering.
Are you flying in very hot conditions?. Have you checked that all your motors are spinning freely?. Could there be any physical resistance on the motors causing them to pull too many amps? Low timing should mean cooler esc's as well.
