ChrisMohrSr
I am starting to get along with my newly arrived AeroSky 550, but I have some questions that are not answered on the very sparse instruction sheet that comes with the bird.
Before I did anything I followed Dave Herbert's advice and I reset the switches on the transmitter to those he specified in his YouTube video.
I then determined if I could lock and unlock the multicopter. I could and was impressed by this very good safety feature.
I then attempted to adjust the Gyro. I followed the directions on the instruction sheet and nothing happened. The LED 1 (whichever one that is. It is not indicated on the sheet.) was supposed to flash for 5 seconds. Nothing happens, nothing flashes that I can see. Moving the sticks to the indicated positions produces NO results of which I am aware.
What I need is for someone to take me from there, step by step, to the complete set up of the machine. I need someone to explain things that are not even mentioned on that sad instruction sheet. Things such as:
How and where do I connect the audible timer?
How do I get at the board? Must I take the machine apart in order to inspect or work on the board, if need be? Removing all those screws is time consuming and annoying. Then putting them back . . *&$#%^@#*
THEN . . if I ever do get the Gyro properly adjusted, there is the matter of the switches. The sheet states that -100 is the onlock position and +100 is the unlock position on the Channel 5 switch. However, the Channel 5 switch has a "0" and a "1" position. Which is the -100 and which is the +100?
The Channel 6 switch is supposed to be a three stage toggle switch. It is only a two stage toggle switch so setting it would seem impossible. Then there are the words Baro and Mag. They should be defined and explained for the Newbee.
It truly boggles my mind that the attitude of the manufacturer seems to be, "We designed and built this great machine, let the user figure out how to get the most out of it. We can't be bothered with creating a complete and useful User Manual". Well, someone should bother. Someone completely familiar with the AeroSky 550 should sit down and write a well illustrated User Manual for that bird. I'll bet they would sell online like the probverbial hotcakes. Then they could do the same with all Chinese rc aircraft. Not a one of them seems to have a decent manual. There's a fortune to made out there.
