Awesome Aerial Photography System! $3120 + shipping
Tarot 680Pro Hexacopter/Multirotor (UAV/Drone) with extended arms for greater lifting power! This is an excellent system to use with Mirrorless cameras like the Sony A6000 series cameras (camera NOT included!). Includes the wiring for a Sony A6000 - just drop the camera on the gimbal and you are ready to go!
This version of the 680Pro has extended arms that allow for 15" props vs the standard kit with 13" props. This is not a stock configuration, it has all the best components configured together to make for a solid, stable & reliable photography platform.
Any questions on this system, contact me!
More details on this system...
Tarot 680 Pro Extended
T-Motor MN3510/630kv Motors
T-Motor 40A Electronic Speed Controllers
Tarot High Efficiency Carbon Fiber Propellers 15"x5.5 (Full set plus a spare CW/CCW)
DJI Mini iOSD for FPV
DJI Naza-M V2 Flight Control System
Immersion 600mW 5.8GHz Transmitter
Retractable Landing Gear - Activate after lifting off with a switch on the radio.
HDMI to AV Converter Cable for Sony A5000 A6000 cameras
Flytron IR Shutter Release
IBCrazy Blue Beam Ultra 5.8GHz Antenna
Multistar 16000mAh 4S Battery (x3)
Multistar 10000mAh 4S Battery (x2)
Grouse House Technologies GHT NEXt Gimbal V3 with Lightweight 2 axis mount
59/10 Grommet & Damper Interface
Simple BGC 32-bit gimbal controller
Futaba 10JH 10 Channel Radio
Futaba R3008SB Receivers (x2)
Flysight Black Pearl 7" Monitor with built in receiver plus spare battery & AC Adapter
IBCrazy 5.8GHz Helical Antenna (x2)
** Camera not included **
