Tests finished. The CX730 is going back.
It does not improve significantly on ANYTHING that the GH2 has to offer - apart from a more pleasing colour balance straight out of the camera in the 1080p25 mode. Otherwise, just like the Nex 5, the image is generally soft compared to the GH2 and the 1080p50 option drastically washes out the colour. It also actually loses fine definition. The BOSS stabilisation DOES soak up more Pan and Tilt movement than any other OIS that I have tried but the lack of Roll stabilisation cannot hide a wobbly horizon.
The painful Touch Screen menu access is ... painful ... and the ridiculously limited manual options are ... ridiculous. The availability of remote zoom is a plus point but if all the above boxes are not ticked, who needs a zoom? It also conforms to the current fashion of in-camera battery charging, rather than a separate charger - how stupid - and the lens hood cannot be used at the same time as filters. This means either expose the lens to the elements, and have the devil's own job of trying to clean it inside the automatic shutters which are only open when the camera is turned on, or use filters and protect the lens but be plagued by lens flare the whole time.
A typically lacking and frustrating consumer camera.
Overall score: 6/10
Hi,
i agree with some comments, but i have to say that i'm more comfortable with multirotors technology than camera settings and tech ology and so far, the 740 CX gave me out of the box in an easy way what i needed. I have no doubt the GH2 is better but only if operated ( on my opinion) by someone who knows really about how to fine tune things.
Now a small thing to note :
BOSS is very powerful and if you get some details missing in 50P, most of the time it's because you have small vibrations / wobbles on the gimbal. This causes a kind of mini motion blurr and you miss many details on trees and stuffs like that. But with a proper gimbal , without vibrations, you get really good results. I would not be able to tell about colors ( i don't know anything about these stuffs) but definitly details are really impressive when the camera is mounted on a solid gimbal. Roll and tilt stabilisation are the duty of the gimbal and it's stabilisation, and such camera will give it's best results only with a solid gimbal setup. BOSS will help to catch back small hick ups, especially in the wind and will smoothen panoramas at low and medium speed. No camera can corect mechanical vibrations or problems that are not cured at their sources.
My personal feeling after testing the CX 740 ( 32 GB memory) is that the camera forgives many small things that a reflex camera can't help with, but will be limited in it's quality by it's " consumer" settings when you can have access to a really different world with a Reflex camera like the GH2, even more with it's hacks, but the smallest trouble in flight will make you loose maybe the scene...
Anyway, i like the 740 CX a lot, i use also the 550D with the Magic lantern firmware but i had better results with the CX 740 because of my lack of camera settings knowledge.
Regarding filters and lenses, with a bit of carbon and imagination, all can be worked out
Best regards,
Fabien
