Hello everione!
I have some problem with the skyjib.
I have put to geather lots of lots of kopters espacially MKs. I building My own frames fro MK electonics.
But I never had a kopter bigger than 90cm diameter.
I have the AXI 2826/12 with aerodrive 8, 15x5 Xoar. I have a serious motor heat problem! Motors are completly leveled. I have 4x5S 8000mAh on board. payload is not more than 6kg (full flying weight is less than 17kg.) The kopter makes a yaw move when its lifting from the gorund. I have seen Kopterworx test video with the same setup and they did not have that problem. What should I change? Do I have wrong P I D????
If someone can help Me it would be great!!!!
Thank You
Dasco
Thank You
Dasco
