Seeking recommendation for retractible landing gear for 25mm tubes on homebuilt hex
ChimpanZed
All,
I'm designing and building my own heavy lift hex with a wheelbase of about 950mm. I'm looking for your recommendations on some good quality retractible landing gear that will fit 25mm OD tubes. The number 2 and 5 arms are at the 3 and 9 o'clock position; ideally I'd simply clamp the landing gear directly under these arms. The ability to replace the leg portion with longer/shorter CF tubes would be nice but is not critical.
I've seen some stuff from Tarot and on goodluckbuy.com but I have no experience with any of it. Can any of you suggest a landing gear setup that might work for my purposes?
Many thanks!
-CZ
Carapau
Well, the best retracts that I have used have been the DJI S800 ones. They use 25mm tubes for the main part of the legs although 12ish mm for the mounting rods so not sure if they fit your requirements.
