Benjamin Rowland
Anyone ever used Scorpion motors on a Cinestar?
What is Scorpion![]()
Benjamin
Interesting. But keep in mind that the weight is higher than the KW8's and there is no 6mm prop shaft adapter (says it has a 5mm) which would add to the cost. KW8 would be about $ 117 each. Matjaz earlier told me they are 710Kv.
I'm betting you favor the KW8 motors?:tennis: (That is the first time I've used a smiley, but it seemed appropriate.)
Wish they were in stock.
Well i like to check on other stuff also. Well KW8 are good and proven trustworthy. But i am always curius.
you dont get worried when you see the red text saying it is over the rated current?
Yeah, i wonder what changes, if any, kopterworx has Tiger do to those to make the specs slightly different.
I'm looking at the Scorpion SII-3026-710 --- if the shaft was shorter it could do the trick. I could use them to lift an Epic with my Cinestar without a problem.
APC | 12 x 6 | using 59 amps for 3400g of thrust be careful with your choice of ESC's | ||||||
