MombasaFlash
Heli's & Tele's bloke
Although this has been mentioned in the 'Rant' thread I want to cast the net again in my search for a solution, since the dïckjerks at DJI are prevaricating and wasting time over pennies.
The issue is that, although they apparently worked normally when first installed (a few weeks ago) since the upgrade to the IMU.v2 the S800 retracts have become unreliable. They work every time on the ground (supported off the ground, of course) but in flight they may work once - it might be smooth or it might be juddery and hesitant - or, most of the time, they don't work at all. And yet, land it and immediately support it off the ground and they work perfectly!
Could it be a voltage drop when in the air? Who knows. If it is, why did they originally work?
My question is to those who have the S800 retracts. When you activate them, i.e. make them go up, does the little LED on the retract control board change momentarily from green to red? Coz mine does.
If everyone else's green LED stays green then this could be pointing towards a faulty board.
