Hey everyone. I have reached a dead end and desperately need help.
I have the latest Z15 5d gimbal which uses a 7 pin instead of a 3.5mm jack.
I am running the GCU into the IOSD into the 4 pin video in jack. There is a 7 pin cable running 4 wires into the lightbridge for power, but the manufacturer has not included the video lines on this cable.
There is an 8 pin video out from the IOSD, of which 2 lines are for video/ground. I am running this into the lightbridge via the 3 pin plug.
Everything powers up and runs perfectly but I can not get the lightbridge to acknowledge the video source. The lightbridge air and ground system connect up perfectly.
Your help would be most appreciated if you can!!
Thanks in advance for ANY suggestion
