Reimagine Movement: The DJI OSMO
Introducing the DJI Osmo
DJI Osmo - Moments
DJI Osmo - Evolution
OSMO – REIMAGINE MOVEMENT
Motion without blur. Action shots without shake. Perfect video even when you move. Thanks to advanced technologies specifically designed to keep the camera flat no matter how you move it, the DJI Osmo helps you record videos and take photos like never before. It is much more than just a camera. It helps you create with more freedom than ever.
THE WORLD IN 360°
The Automatic Panorama mode makes shooting 360° panoramas easier than ever. Just hold the Osmo up above your head and tap the shutter release. The camera will rotate, capturing images as it goes while staying completely level. Don’t just get a snapshot of a piece of your travels. Make a memory of the whole scene.
POWER IN YOUR PALM
The grip on the Osmo is precisely engineered with materials selected for comfort and durability, and designed to ergonomically fit the palm of your hand. Conveniently placed buttons and controls keep important functions by your thumb for instant access.
REMOTE CONTROL
All of DJI's Smart Shooting modes can be controlled and triggered by remote control from within the DJI GO app on your smartphone. Mount the Osmo on a tripod, or any of the other available mounts, and take a few steps back to a position from where you can easily overlook the scene and control the camera.
PERFECT VISION
The Osmo’s Zenmuse X3 camera works as one with the stabilization system. It brings you 4K video at 24, 25 or 30 frames per second so you could even shoot for the big screen, and captures photos at 12 megapixels in Adobe DNG RAW, opening up shots that you never thought possible before.
The Osmo is also compatible with the all-new Zenmuse X5 series of cameras, bringing you highly stabilized imaging with all the benefits of a large M4/3 sensor.
ADVANCED GIMBAL
The technology to keeping a camera smooth in the sky has long been a core DJI technology. This expertise was pushed to its limit in creating the X3 and its gimbal, giving you a completely stable camera you can hold in your hand.
The 3-axis gimbal knows how the Osmo is moving, allowing it to correct for your movements every second. Using a network of sensors and advanced algorithms it keeps the camera perfectly level no matter how you move.
This level of precision is only possible because of the ultra-fast, custom-made processor that is unique to DJI. Operating at speeds that allow the system to compensate for motion and tilt in real-time, this processor controls motors on all three axes: yaw, tilt, and roll.
ACCESSORIZE
The Osmo supports a number of mounts and extensions so that you can use it in almost any situation. A Tripod lets you set the Osmo down for added stability or long-distance control. The Bike Mount lets you take the Osmo for a ride and an Extension Rod opens up a range of brand new angles.
INTELLIGENT SLEEP MODE
Put down the Osmo, and it automatically enters into sleep mode after a set amount of time. This not only extends the Osmo’s battery life, but also increases the lifespan of its advanced electronics. When you wake up the Osmo, it’s ready to go.
