Recommendations for 5.8Ghz Tx!
PeteDee
Mr take no prisoners!
Looking for a 200mw 5.8Ghz TX, what are you using and where do you get them from?
Also looking at a good 7 inch well priced hi res screen.
Is there a list of good online sites to buy gear from?
Thanks.
Pete
PeteDee
Okay so I did some more research and looks like the unit sold by HK and others all seem to be pretty much out of the same factory but seem to be good bang for buck if you can get it to work.
Many seem to have problems with the video and power connections due to different info on the same bits of documentation, not good.
Are there other good choices?
Pete
PeteDee
Thanks Jake,
Their "long distance" Tx does not list the Tx power output, not sure if it is 200mW or 2Watts.
Pete
gpforet
For screens, I went with http://www.amazon.com/gp/product/B007SLDF7O/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
They're not hi-def but neither are my feeds. I use two. One with a FPV camera with the hornet OSD for pilot fed via 900khz 800mw
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=13442
and one being fed by gopro Hero 2 on the 468 gimbal to the HK 5.8mhz 400mw.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=27145
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=18649
My only complaint is the 5.8mhz receiver gets really hot running from my 3s distro which powers both monitors, both receivers, and a 12v digital voltmeter.
My FPV camera, and both transmitters are powered by a 800mah s3 which gives me about an hour of run-time.
Aircraft is F550 with T-motors, NAZA+GPS, APC 10x4.7 props running off of 2 s3 4000 turnigy nano-techs in parallel.
Thanks.
Pete
