Prop Trimming Fixture
Harvcopter
This is a Harvcopter fixture for trimming 5" props to any size you want. (less than 5") I can make these fixtures to your specs. Mounted in the fixture is a 5030 Gemfan prop that was trimmed to 110mm. I now use DAL props almost exclusively because of their durability. 5040 DAL props trimmed to 101 mm work great on a 200QX. Props can be trimmed quickly, accurately using this fixture. Just slide a razor blade through the prop tips at each end of the fixture and away you go. It is especially useful in the field.
