After I saw that video a couple of weeks back I was happy to pay the extra for the pricey Vislero packs. Had to smile when the caption read 'a similar pack from another manufacturer' (plug, plug!).
After the initial MRC baptism with the MK Octo I bought an AD-8 and filled it up with the same MK stack plus an I2C isolator board. I also wanted bullet connectors on the motor leads, so that individual booms could be removed without a soldering iron, and this meant that the boom mounted LED cables also had to be unplug-able. In addition there are two extension PCB's supplying 12v direct, 12v switched and 5v direct to an array of pin connectors on veroboard for powering LED's, possibly Superlights later, maybe downlink Tx (although that will probably have a dedicated and separate 3S LiPo) and the isolator board. Isolating the I2C feeds from each BL called for even more non-standard stuff and so as a result the whole installation is not nearly as neat and tidy as the bog-standard Octo build. There is a regular old spaghetti of wires under the stack so heaven knows what stray fields are being created.
I will get some pics done.
Initial flights have been trouble-free, I just hope nothing falls off any of those infamous MK boards.
