MombasaFlash
Heli's & Tele's bloke
I have been doing a photo job the last couple of days. As ultra resolution was not required I kept it simple with the NEX-5n on the AD-8 and this gave me a safe ten minutes per flight. I was unpleasantly surprised to find that half the shots I knew I took were not on the card. I checked the gear and everything worked so I went out again this morning.
All ready to start, check the shutter release and ... same thing. Nine out of ten shutter commands produced no response. Huh?
I eventually found the problem. With the NEX on Auto-Focus and the HDMI cable plugged in and powered up, the gentLED shutter release did not work - most of the time. Switch to manual focus and it works every time. OR ... remove the HDMI cable and leave the NEX in Auto-Focus and it also works every time. Since the clumsy great HDMI cable is required in order to transmit live video from the NEX there is no option but to use manual focus.
As a rule I ALWAYS use manual focus, along with manual shutter speed, aperture and sensitivity but the sometimes soft imagery of the NEX prompted me to try Auto-Focus for a change and because of that I have discovered this weird anomaly.
I wonder if Sony know about it. Surely this sort of issue must be fixable with a firmware update?
Here is one of the pics.
