Newbie!
Bahnzai
New member, same problems. I have had flyaways, but that adds to the excitement of the hobby.
I am presently setting up a Tarot 680, Spektrum 9020, WKM -V2. The assistant is helpful, but this is different from my NAZA M V2. X1 and X3 are reversed. I followed freemarlochip on youtube for the Naza, but the WKM is a bit more challenging. I don't want the heart break of another flyaway. On the table, I am getting 2 purple flashes. I know that means a stick is not centered. Am I supposed to start with throttle mid way DX-9 or, does this mean sticks are not centered on the assistant? After doing the calibration, it appears rudder is to be trimmed to get it to go green. Should I center it via sub-trim? A little help please?
rudder should center after calibration, throttle should be centered before finishing calibration. sticks not centered is normal during flight but WKM will flash two greens anyway
i don't think sub-trim is the way to go for the rudder.
Bahnzai
I have tried to re-calibrate a couple of times. Elevator, and Aileron center to green fine. However, rudder (if all trim, and sub-trim are zero) comes up as black, not green in center. After calibration, I can get it to green, but I have to use trim or subtrim. I don't think I had this problem with Naza.
Does anyone else use Spektrum with Wookong. I would be interest on how they set up the 6,and 7 channels. or X 2 and X 3.
