New Vibration Absorbing Kit for DJI 4114 Motors
The new vibration absorbing kit for your DJI 4114 motors helps reduce unwanted vibrations that may be caused by your motors. The package contains new soft dampers and new motor screws designed to absorb high-frequency vibrations and prevent them from reaching your IMU and gimbal. To install the new items, simply unscrew the old motor screws and remove the old dampers. Then put the new dampers in place and tighten the new screws.
Note: The new soft dampers must be used with your original metal gaskets and the new motor screws.
Suggested gain value settings when using a DJI S900 with the new vibration absorbing package are below.
For A2 flight control systems:
Basic: Pitch 120%, Roll 120%, Yaw 120%
Attitude: Pitch 190%, Roll 190%, Vertical 120%
For WooKong-M flight control systems:
Basic: Pitch 130%, Roll 130%, Yaw 120%
Where to buy: DJI authorized dealers
