Quick update on the new Pro Tricopter Delrin Kit by fpvmanuals.com.
More info and pictures on the kit are here:
http://www.fpvmanuals.com/tricopter
Key features/highlights:
- The kit can be assembled with the motors pointing up (regular) or down, for “zero prop-wash” effect. Your choice!
- Front arms can be folded back for transport/storage and can be secured with a screw and nut, if required for acrobatic flying
- Kit available in black or white
- Frame parts made from precision laser cut Delrin: 3 Motor mounts, complete Yaw mechanism, 2 main body frame parts
- 1 Camera mount for GoPro and/or flight cam. Made of vibration slowing bamboo.
- 3 feet made of clear acrylic
- 1 flight controller cover made of fluro acrylic that protects your flight controller in case of an upside down crash.
- Weight: Fully flight ready built kit with all electronics, flight controller, motors, escs (without battery) weighs 630g. Kit frame and motor mounts: 150g, kit hardware: 50g. Total kit weight: 200g.
- The Yaw mechanism uses precision ball-bearings that are pressed into the Delrin, requiring no glue. The axle for the Yaw mechanism is made of airplane grade aluminum. The assembly provides for ZeroYawSlop. The kit also comes with ball links and threaded rod to create a slop free push-rod to connect the servo arm to the Yaw control horn.
- Includes all frame and motor mounting hardware: screws, nuts, ball bearings, servo to motor pushrod using ball links, Yaw axle, and stand-offs
