sophia lee
This Solid-State ToF Infrared LiDAR CE30-A is equipped with its special hardware design. It can complete the measurement of wide horizontal FOV and output the grey and depth information at the same time. With its specially optimized obstacle avoidance mode, the detecting area of interest could be set, and the single-point projection distance information of the nearest distance point could be transferred through CANBUS. Compared with single-line scanning LiDAR, CE30-A does not contain any rotating compartments, which could ensure the reliability of the long-time work and a wider vertical detecting range.
The ranging principle of CE30-A is based on Time of Flight (TOF). CE30-A emits modulated near-infrared light, which will be reflected by the object and received by CE30-A again. CE30-A calculates the phase difference and time difference between the emitted and received light, which will be further converted to the clearance of the shot scene.
What's Included
What's Included
- 1 x CE30-A LiDAR
- 1 x Power supply
- CAN aerial connection
- 2 x Fix screw
- 1 x Ethernet port aerial connection (optional)
- Parameter1: Typical Value
- Method: Time of flight
- Peak Wavelength: 850nm
- FoV: 132*9 degree
- Pixel Resolution: 320*24
- Frame Rate: 20fps
- Ranging Resolution: 1cm
- Detecting Range2: 0.1~4m
- Repeatability(1σ): ≤3cm
- Accuracy: ≤5cm
- Ambient Light Resistance: 60klux3
- Data Interface: CAN
- Operating Temperature: 0~50℃
- Supply Voltage: DC 12V(≥2A)
- Power Consumption: ≤4.5W
- Enclosure Rating: IP65
- Eye Safety Class: Risk group 0 in accordance with EN 62471
- Weight: 216g
