KK Flight Controller need initial kk2 settings
linter
hi all: when i first started my quad w kk2, using settings i found somewhere on the 'net, the damn thing shook all over the place like the legs were loose. i'm hoping the problem is the settings i used and not something else. can someone here recommend settings that are very basic and very stable? thanks!
Efliernz
Pete
The basic settings are reasonable... it sounds like you may have a prop balance issue. Have you balanced them?
Pete
linter
well, then, what are the basic settings? that's what i'm after!
will check the props but, if they're out of whack, they gotta be wwwway outta whack, given the alarming nature of the bobble wobbles of my bird.
Efliernz
Pete
Which firmware are you running? The default (as supplied) V1.2 or the later V1.5 / 1.6?
It says which on the tittle screen as it power up if you are not sure.
What size quad / weight are you "flying". That is the big question when it comes to gain settings.
Give us the size of the machine, motor size & Kv and prop size and we should be able to help.
Pete
Skywalker
I am also trying to set up my F550 with kk2. The factory setting did not work at all. It just shook and wondered all over the place. I adjusted all of the Igain settings to 0 and the pgain settings to 20. I am not using self leveling. The craft now hovers like a champ, but has very slow stick response, but is totally flyable. I am not sure why this setting works for me, but you may want to try to see what happens. I will keep playing with the settings to see if I can improve.
