rdalemercer
Hi.
I've had my Flamewheel (F450) assembled for about 3 weeks - but due to work schedules and a host of other excuses, I haven't been able to devote much time to sorting out the bits that are needed to take it outside for its maiden flight.What I have done so far is to connect the NAZA assistant to my PC (Win7).
It is recognizing the NAZA and all is good from the channel setting, initial gains set (120,120,120,145), correct prop rotation and the Atti/Manual end point adjusted on the switch and as it shows in the Assistant software.
I have setup the TX as "ACRO" -- not HELI as suggested in the NAZA instructions.
I am using a Futaba MZ14 with a 6014HS Rx and am NOT using SBUS.Here is what I need support with:
1. How to setup the failsafe.
2. How to setup the TX/Naza to perform in-flight (remote) adjustments of the gains.
3. How to setup the expo to provide some dead zone so it's not so squirly around center stick.
and .... any other tidbits of information that you can care to share about setting up the NAZA with Futaba Mz14.
Thanks in advance...I'm sure I will have more Q's as I get this flying...
Dale.
Dale.
