Jason- Welcome to the Forum.
More information is needed about your setup so the membership here can help.
Before you modified an existing unknown brand flight controller's programming on your aircraft everything worked. You changed "parameters" on your flight controller's initial set (default) programming, the changes did not work as intended, you reprogrammed the flight controller back to default settings, and now nothing is working.
More information please.
JB
