Truckzilla
Hi all,
I was looking for some quick guidance for setting up a multiwii board, not in the conventional way.
I was looking to use the acceleration G sensor to limit output to a ESC on a RC car.
I wish to use it for traction/acceleration (& possibly breaking) control on a high speed RC I have been mucking around with.
I figured if the acceleration G rate is lower than the throttle position the Multiwii should be able to pick up on this and determine it as wheel spin and lower the throttle until the two are even. If this makes sense.
Not sure if this has been tried before. I have little grasp of Arduino coding using the Ardruino program for windows, but only modifying and playing with pre-made sketches.
Any help would be much appreciated, Even if it only helps me take a step in the right direction.
Cheers in advanced Simon.
[h=3][/h]
[h=3][/h]
