GotHeliRC.com Mini 600mw Video Transmitter with cloverleaf antenna
GotHeliRC
http://gothelirc.com
http://www.gothelirc.com/shopexd.asp?id=2333
ntroducing the world smallest 5.8ghz 600mw video transmitter (28x21x8mm). With built in clover antenna for compact sleek design and weight saving. Fully enclosed CNC case for weather resistant and heat dissipation. MI600 packed with 600mw of transmitting power give you 2-3km range.
Will work with FlySight RC801 Black Pearl Monitor
Features:
* Ultra small
* High power output 600mw
* CNC case
* 1x M2 mounting hole
* Wide range of voltage input
* 5v out
* Antenna is bendable
Specifications:
Band E: 5705, 5685, 5665, 5645, 5885, 5905, 5925, 5945
Dimension: 28x21x8mm
Total weight: 19grams
Voltage Input: 7-28volts
Voltage Output: 5volts
