Delta Star
Hi everyone! I'm not sure where else to turn. I've tried and tried to figure this out, but I'm getting nowhere. I have a few different issues, so I'll try to paint the whole picture at once. Here is what I am trying to put together:
Important components:
Frame: Scorpion Y650 (Y6, carbon fiber and aluminum)
Motors: NTM Prop Drive 28-30s (20a, 800KV)
ESC: Turnigy Plush 30a
FC: HKpilot 2.5, running Arducopter 3.0.1
Other things I don't THINK matter:
Using a Turnigy 9X with er9X, FrSky w/ telemetry, Xbee telemetry for Mission Planner, and I've added LED lights.
Now, everything WAS working great. I was using 5000mah, 25C Turnigy lipos. It was a *little* under powered, in that it was hovering at midstick and I still mean to add a Go Pro, so I was mildly concerned, but for the moment flying perfectly.
The first thing I noticed was that on all 4 of my lipos, flight duration was only a few minutes, and for some reason the cells were discharging unevenly. I am using an Accucell 6, and always charge at 1C and always in balance mode. When I say the cells were uneven, I mean like 3.5amp, 2.2amp, 1.9amp. That kind of range.
So I read up on it and decided I probably got a bad batch of batteries. Someone, somewhere, recommended SMC lipos. I found one that is 5100mah, 4S, and 40C discharge. Sounded a little more powerful, so I got that.
That's when everything fell apart. I added my LED's and Xbee telemetry at the same time. I don't THINK that has anything to do with my problems, though. What started happening, was that it would drift to the right or backwards (randomly one or the other... not both). It's as if the trim is way off, but so far off that trim can't fix it, and it's not consistent anyway.
I suspected Arducopter, so I played with a lot of settings, but nothing helped. I decided to temporarily invert the ESC leads at the FC. Sending my left motors the data from the right ones, and vice versa. The copter *STILL* wandered either to the right or backward, in stabilize and acro modes.
So I deduced it wasn't likely Arducopter's or the FC's fault. I switched the motors on the left with the ones on the right, and then the problem did shift from one side to the other. Now the copter drifts to the left or backwards, randomly. Sounds simple enough - probably faulty motors... but they're all brand new, pretty much, and why is it such a random result?
I noticed that my new battery also dischargde unevenly, but not as bad at first. It ranged like 3.4a, 3.4a, 3.6a, 3.7a. Until I let it completely drain by accident. After cheating a little to get it charged, now it discharges *totally* unevenly, allowing 2 cells to drop to 1amp and the other two stay at 4.7a. Is this battery toast now? Is there something wrong with my charger or my copter causing all these battery problems?
I read that the props I'm supposed to use aren't the 10x4.5 ones I have, but actually should be 11x7. Should I switch to those bigger props?
Should I get 6 totally different motors? Or just replace a few suspect ones? Should I try yet another battery type? 3S, or 4S?
What would you do?
What would you do?
