I have been tinkering with this for a bit and finally have it complete and on the maiden flight as soon the as the drone lifts off about an inch the motors stop spinning. I have tried numerous things to see if I can fix the the problem with no success. My next step is to get a SD card so I can see the black box logs and find any information that way. Since you are quite knowledgable I thought I would reach out and see if you can pin point the problem. My soldering and assembly is good, below is the list of components I used.
Martian II Frame
Matek F722-std FC and Matek PDB connected with the ribbon cable.
Dys Samguk 2206 2400kv motors
Lumenier 1300 mAh 3 cell battery
Spedix 2-6S BLHeli_S 45A esc (I know it pobably overkill but its all I could get from my local store)
Taranis x9d plus radio
FRSky x8r receiver
FRSky battery sensor.
The all up weight of the drone is 466g
I configured everything using Betaflight Please let me know if there is something that you can see that I need to do to fix the problem.
Thanks for any help
Ed
Martian II Frame
FRSky x8r receiver
Thanks for any help
Ed
