ksrimoungchanh
So, got WKM with F550 and FUTABA kit. Billowy 4S 4000mah battery.. fly for about 3 days.. seems to fly fine then, no Green LED during calibration.. What I was expecting was:
1. switch mode 8-10 times go get constant Blue for horizontal calibration.
2. turn on horizontal plane completely till it turns Green for the vertical plane calibration. Then wait for white.
I had the calibration turn Blue, but when I was expecting the GREEN, it was just off. I continued to calibrate the vertical as if it was GREEN and it completed with a white as expected. If flew normal.
I sent it back to reseller. Reseller said that they replace the LED and also installed/tested and sent it all back RTF.
everything flew great.. I normally do a GPS test, fly about 25ft off ground.. hover for a few minutes.. fly it upwind and hover, then power off TX to activate RTH.. I only have 2 batteries for now, and only run back and forth between the park and the house once a day.. so, first charge batteries is out at the park.. about 15miles away... then I come home charge for a 2 battery hover around in the yard. That is about all I get in a day's flying time.
About a week later, maybe 10 batteries.. (don't fly everyday), the BLUE LED indicators are not working. How I found out?
This afternoon, I took it to the park. powered on and waited for GPS purples.. normally about 1-2 mins or less, but this time, no purple.. I waited about 3 mins.. no purple. I powered of the WKM, and on, and waited again... and waited, and waited.. No purple.
So, I decided to calibrate.. in the process, I notice no BLUE. a ha!, purple probably needs BLUE and RED.. did the same as above.. continued anyway and the unit still fly as expected... Have not tried RTH, but have hover, and manually tried to move the hexa from it's hover and it goes back.
I don't think replacing the LED will be the solution alone. There is an underlying issue that I believe will cause a replacement LED to go faulty again.
Any input? my reseller had replace the LED the first time free for me.. assume it was under warranty. But now, they are reluctant.. I don't blame them, but I believe DJI or reseller should help investigate the true issue and resolve it under warranty. I think just replacing the LED was a good gesture and was the thing to do, but maybe was too soon to close the case.
Has anyone had this issue?
I am on 1.28.. that is what the reseller had it had. Don't want to start upgrading/downgrading etc.. without any finding first. Also when it still seems to hover nicely and seems to have a GPS without the purple indicators.
Could it be the PMU?
or could it be the WKM?
Thanks all.
KS
Thanks all.
KS
