wearypanda
I need to decide between building a 900mm or 1200mm hex. Setup will be generally to carry mid size mirrorless SLR (NEX 5r) but it would be good to be able to lift something bigger if necessary. Assuming the same motor/prop combination on each, what are the real advantages of going with a bigger span multi? I am guessing that stability would probably be better, but by what sort of factor? Perhaps keeping the gimbal as clear as possible from the downthrust of the props would be a good thing, but are there any other factors? One thing for sure is that it would be easier to transport a 900mm!
Can anyone help educate me on this?
Andrew
Andrew
