Hyperion MultiOne VENGEANCE 280 Pre-Order @GotHeliRC
GotHeliRC
http://gothelirc.com
Get 8x FREE HQPROP 5045 BULLNOSE if you PREORDER NOW.
Introducing the Hyperion Multione Vengeance Plug And Play FPV Racer! Welcome to the new world of FPV Racing!
  • Fully Assembled: No building or firmware loading necessary!
  • On-Screen Display (OSD): Program or set up your Vengeance on-the-fly, no computer needed
  • In-Flight-Adjustable Single-Axis Camera Gimbal, Self-leveling during flight
  • Vibration Dampened Second-Camera Mount
  • 600TVl 1/3 CMOS High-Quality FPV Camera
  • Robust, Pure Carbon-Fiber Frame with Carbon Exoskeleton Reinforcements
  • Stress-Flex Designed to Withstand Impacts, Mass centralized for high-rate turning
  • Black-Anodized, High-Strength CNC Aluminum Boom Mounts
  • Tough, Translucent Polymer Landing Legs with Built-in Directional Red-Green LED
  • 8 Forward-Tilt Motor Mounts for Aerodynamic Efficiency and Top Speed Performance
  • Four 2804, 2300Kv High-Output Brushless Motors
  • Custom Compact BL-Heli 20A Motor Controllers (ESC)
  • Visual LED Flight Mode Indicator. Easy to confirm your flight mode
  • Pre-loaded with Three Flight Modes: Normal, Altitude Hold, or Acro Mode
  • NAZE Spec 32 Bit Flight Controller 7DOF (with BMP sensor)
  • Altitude Hold via Integrated Barometric Pressure Sensor (BMP)
  • 3S and 4S Battery Compatible. Hyperion G6 HV LiPo Suggested (not included)
  • 5.8GHz Auto-Scan 32CH Video Transmitter (VTX) w/ Race BandVTX selectable for either 20mw/200mw output
  • Tuned 5.8GHz CloverLeaf Skew-Planar Antenna
  • Plug-n-Play Ready for Optional GPS modules
  • Built-in Low-voltage Audible Alarm
  • Compatible with Single Wire* or Traditional Receivers (*S-Bus, Horizon Spektrum Satellite, or Hyperion Compatible receivers)
  • Box includes Carry Handle and Foam Racer Cradle + Parts Holder, for service as field case
  • One Set 5x3 CC/CCW Propellers Included
http://www.gothelirc.com/products/2...e-280-plug-and-play-fpv-racer-preorder/?bc=no
