Yesterday I took the AD6 off the shelf where its been parked while I've been playing around witrh the WKM hex, wanted to give it a test flight and make sure everything is good to go before putting the Nex 5N on it. Got off the ground and first thing I noticed was a strong tendency to yaw back and forth. A tiny bit of either left or right on the rudder held it better but still not right. Climbed to treetop level and clicked into GPS, bad toilet bowl circling, hmmm...
To cut to the chase here, it appears that all of a sudden there is an RFI problem with the AD6. If I disconnect the Navi from the F/C and fly just with the F/C it doesn't yaw, reconnect and it starts the crazy stuff again. Took the Navi setup out and after a test flight to verify the standard hexa was flying right I swapped its Nav setup with the one from the AD6, no yawing, good GPS hold so its not a problem with the Nav boards on the AD6.
Swapped the spare Nav boards onto the AD6 and did a test flight, slightly better but still doing the yaw and TBE in position hold. I know this set of Nav boards work well, they've been on the MK quad test bed frame and flying with one of the spare Mk flight controllers and I2C converter. So somehow the AD6 has developed an RFI problem where none existed before. The only thing different about the AD6 and the standard Hexa is the I2C isolation board that lives in the stack of the AD directly above the Navi board. I suspect that may be the source of the RFI but to test that theory I'd have to do a fair bit of work removing the servo leads from the BL's and reconnect the PDB I2C connections.
I did have the boards off the stack of the AD6 a while ago and after putting them back there's nothing different now than before but suddenly the RFI is a problem where it wasn't before and that worries me. Next I think I'll try putting a bit more distance between the isolator and Navi but I can't go all that far due to cable limitations as well as still have the dome fit over all of it. Lesson learned, if things are working well, don't take the thing apart for any reason unless absolutely necessary!!!
