how to tell if a motor is going to fail
JLO
Does a motor has signs that its going to fail, is there a distinct sound, or feel when turning them by hand that it could fail that its better to change it than to risk it fail in mid flight I have DJI motors on a F550
thanks
apeman88
For most brushless motors... the bearing will go first. You will hear the bearings making grinding weird noise... then it's time to service the motors or replace them. If memory serves, most brushless motors are rated at about 1000hrs +/-.
hover
Don't mix up with other bearings! These are the highest quality stainless ABEC-5bearings.
Just dont mix bearings on the same motor or the whole quadrocopter? Maybe the 4 motors could spin slightly different with different bearings.​
jes1111
Batfire
QUAD HACKER
Hmmmm.......
Good question. I have a motor that went on my X830 quad and those are dynamically balanced kv650 motors ($70) a pop. Anyway it momentarily failed in flight causing the death flip. Luckily no real damage was done only a few feet off nice grassy area. I took the motor apart and found a small washer that looks like it had been in there since day one.
I put the motor back together and ran and within a few minutes it momentary quit again. Then you can start it right back up. No bearing noise, bearing turn and look fine and see nothing wrong with inside of motor, all wires well connected and even tested them with meter to make sure ok. So I have no idea what is wrong with motor. Since these come with motor mount as part of motor assembly just put it in spares bin.View attachment 5675
apeman88
It might be a almost break or short on the windings. Those wires are coated with super thin insulation material and are heat rated. If the motor runs above rated temp... It will melt the insulation resulting in a short or act as a fuse and break.
Batfire
QUAD HACKER
Hi Ken
I have never run motor hot, I monitor this closely since doing evaluation of X-830-H quadcopter. I, as mentioned earlier did find a tiny washer in motor which was rubbed very smooth so sure it’s been there since factory new. Now as far as the windings honestly I can’t tell my multimeter doesn't show an issue but that doesn't mean there is not one.:black_eyed: Obviously or not so obviously the washer could have caused the issue you mentioned and I just cant visually see the damage.:apathy:
See blog. http://www.rcgroups.com/forums/showthread.php?t=1670862 Tutorial number 4 and you can see what I have been going through on this quad. I guess the only real thing I could do to find issue is send motor back to manufacturer. Like I would ever get an answer from china or see the motor again.:dread:
Thank you for your comment though.
