Peter Schaming
PRARIX
So, a year ago I decided to put a thermal imaging camera aboard, a FLIR Tau, in addition to the other equipment. I became obsessed with preventing an expensive crash, so went on to develop a parachute rescue and recovery system. The smaller sized unit weighs about 160 grams, stands under 3 inches high, and prevents crashes. A larger unit weighs about 270 grams, as the parachute and case are larger.
There are limitations. It is not for sport flying, and there is a dead zone near ground level where it just wont open fast enough, but overall for photography up in the air, it works great. I am going to put it on the market shortly.
On three occasions, the cords got tangled somewhat in the props. The cording is kevlar, so they held up fine. The parachute and the quad never sustained any damage from the entanglement. Once when doing a flip, and another couple times when a fly away occurred, and/or it quite was windy. The motors are either shut down or in the process of shutting down, so no damage occurred, and the landings were not that much different from normal. I will get some videos posted shortly on youtube.
I found that a number covers for quadcopters that are in the 3 inch range, so kept the profile low. It can be mounted directly on the quadcopter, or mounted on a piece of carbon fiber plate (with standoffs), to also act as a shield.
The electronics are connected between the battery and main feeds for the quad. In the event of failure, the motors shut down, and a parachute ejects. As stated before, there are limitations. To get the microprocessor, sensors, and software to understand the difference between normal flying, and crashing, took some time, and of course, it can always be improved. I have become an expert in crashes. I have purposely crashed a test quadcopter hundreds of times, and of course, initially with a parachute that didnt always open, at first. Usually from a height of 75 feet or more. I just realized that the parachute I used was getting old, having been used well over 75 times, and thought, its time for a new one. The material is 1.1 oz nylon, very strong, durable, and as I said, will withstand a lot of openings, bad conditions, etc.. When tweaking parts, I would sit and release the parachute into a fan system for hours on end. They really hold up well from repeated being abused.
The tubing is carbon fiber, the hardware custom made, and I, or someone I have trained, will solder the electronics.
So I decided to call the company PRARIX. Parachute Rescue And Recovery Innovations for multirotors. (The X is shaped like a quadcopter).
It will save the quadcopter, and expensive cameras, and other equipment. Now thats, peace of mind.
