How to get extra room for FPV equipment on a F450
LeeT
Wannabe AP Dude
The 450 does not have a lot of room yet alone enough for adding FPV equipment. I thought I'd share how I added extra room to my F450. The last time I crashed (several months ago), I knew I was going to get into FPV. I had already added the top deck using standoffs from Newark Electronics (http://www.newark.com/raf-electroni...-al/spacer-standoff-hex-al-4-5mm-x/dp/27T8047), but needed to move equipment around to make room for the future additions.
The first thing I did was to clean up the wiring, minimizing the amount of extra wire, and running multiple wires in braid. (Pics 1 & 2)
The next step was to move the VU, receiver to the middle deck. The Naza was already there. One of the advantages of setting up the FC this way is it allows you to put the FC directly in the middle of the quad, right at the center of gravity. (Pic3)
As you can see the bottom deck has been cleaned out allowing for the addition of the FPV equipment. (Pic 4 & 5)
The final setup is shown in Pic 6 & 7.
As a side note, the GoPro is mounted using a Sorbothane sandwich. Sorbothane on the top and bottom of the bottom deck, with G10 on the top and bottom. The screws are there as a failsafe, nuts are held in place with Locktite red and not tightened down. The Sorbothane is very sticky, however I want the insurance with the screws and nuts. This mount works very for Jello free videos.
Dewster
That's a nice build. I didn't want my battery hanging out in space so I slid it between the arms of the F450 and kept all electronics on the top plate. The wiring was a mess, but kept contained under a Tupperware like lid. I was my test quad so I wasn't concerned too much about aesthetics. My Y6 was neatly organized, but my next build will have the batteries between the plates of my F550.
You certainly have to get creative when wiring the F450 with all of the gear.
I had a similar issue, so I bolted on a camera flash bracket like this and now have the GoPro way out the front, so that it doesn't get the props in the frame. I balanced the CofG by just having the battery mounted a bit further aft.
