How do I adjust neutral position on Tx sticks back to zero?
eturn23
I plugged my DJI FlameWheel F450 into the Naza assistant software this morning and noticed that the neutral position of the Elevator control was somehow "bumped" to -85. When I push the Elevator up it maxs out at 880. When I pull it down it goes all the way to -1000. Rudder and aileron go to zero when I take my hands off the sticks and have full range from -1000 to 1000. Throttle also has full range.
I don't know how to reset the Elevator control on my Spektrum DX8 radio so that when I take my hands off the right stick it returns to zero. I tried re-calibrating the sticks in the assistant software but that didn't solve the problem. I think I have to make the adjustment using my Tx, but I don't know how to do that? Any ideas what might have caused the change? Yesterday all the controls were at zero (except throttle, which I keep at -1000 when I'm not flying).
Thanks for the help.
Here's my setup:
DJI FlameWheel F450
Naza V1 with 3.14 firmware
DJI 30A ESCs
RCTiger 770 kv motors
APC 10 x 4.7 props
V2 PMU
DJI GPS module
ZenMuse H3-2D gimbal with GoPro Hero3 Black
4500 mAh / 14.8v / 4S / 30C batteries
Spektrum DX8 Tx
Spektrum AR8000 Rx with telemetry
Flight modes: GPS, Attitude, Failsafe
Return to Home failsafe
No IOC
Gains 120, 120, 120, 120, 80, 80
Benjamin Kenobi
Easy? You call that easy?
Added some trim by mistake? You may have adjusted your endpoints (look under dual rates, D/R). You have to move the sticks with a DX8 whilst looking at the D/R screen to see different directions of movement. Good luck! Plenty of help on the forum.
PS- How new are you to all this?
eturn23
Ben- I am pretty new to R/C quad copters. Built my FW F450 in late June so I've been flying for about a month and a half.
I adjusted the Elevator trim so that the neutral position is zero, but that changes the range from -1000 - 880 to -940 - 940 in the Naza assistant software.
When I look into the D/R and Expo menu on my DX8 radio, the D/Rs are both set to 100 and the Expos are set to 0 as they always have been. There is a -2 below the lower left quadrant of the graph with an arrow to the right pointing at a -1 under the right quadrant.
The Aileron screen has a 0 - 0 below the graph and the Rudder screen has a -1 with an arrow pointing to a -1 below the graph. Could this be the problem?
I would like to get things back to the way they were yesterday where I have full range of the Elevator and the neutral (hands off) position is zero.
